Veröffentlicht Wed, 13 Jan 2016 22:00:30 GMT von Don Mayberry SSI
Why would my mail menu under file be grayed out?
Veröffentlicht Wed, 13 Jan 2016 22:04:58 GMT von Tyler Behuniak Professional Services Assistant
Hey Don,
The mail option is generally greyed out when you do not have a compatible mail client installed. If you do in fact have a compatible mail client installed, please submit a ticket through our portal and I will be glad to troubleshoot the issue.
Veröffentlicht Wed, 13 Jan 2016 22:11:44 GMT von Don Mayberry SSI
Its a question from the city of pensacola after upgrading to Fortis 6.8
I noticed the my vm 6.8 also has the same issue. Ill put in a support request
Don
Veröffentlicht Fri, 29 Apr 2016 16:24:15 GMT von Gregory McDaniel
I'm in 2.6.0 and it's greyed out on a workstation that has Outlook 2013 installed and other applications can launch it with their mail features.  I have the "Documents: E-mail" user feature set.
On another workstation without a suitable email client the option is enabled (same user, myself) and summons the mail dialog, but when I try to proceed I then get an error dialog "There is no email program associated to perform the requested action. Please install an email program or, if one is already installed, create an association in the Default Programs control panel."
Veröffentlicht Fri, 29 Apr 2016 16:30:48 GMT von Tyler Behuniak Professional Services Assistant
Hello Gregory,
Check out this FAQ article that should help with getting the mail option enabled:
https://www.docuware.com/support_faq/index.php?action=artikel&cat=191&id...
Veröffentlicht Fri, 29 Apr 2016 19:21:16 GMT von Gregory McDaniel
Thanks, I hadn't seen that article.  I did go through it and added the Wow6432Node key; the other two were already in place.  I re-started Fortis but there was no improvement.
Veröffentlicht Mon, 02 May 2016 13:49:44 GMT von Tyler Behuniak Professional Services Assistant
OK - in order for us to troubleshoot further please submit a new Support Request.
Veröffentlicht Mon, 02 May 2016 17:24:55 GMT von Gregory McDaniel
I tried to but because we have a vendor relationship your resources are not directly available to us.  Please post a troubleshooting checklist here.
Veröffentlicht Mon, 02 May 2016 17:27:55 GMT von Tyler Behuniak Professional Services Assistant
The troubleshooting steps are all listed in the FAQ. For more assitance please reach out to your vendor.
