Veröffentlicht Mon, 10 May 2021 14:29:17 GMT von Rhys Woolley Software Developer
So I'm trying to create a system which notifies someone about a document every 30 days. After 90 days, this document will have a Keyword field called "Status" which will be filled in with "Expired". If for some reason someone doesn't complete the task in the workflow then I want the workflow to be terminated after 90 days and the document to be rendered "Expired"
Any ideas on how to do this? I was going to use a Condition but the main problem where to place it in the workflow since Task only has one output (only one decision) and anywhere else would cause problems.
Veröffentlicht Mon, 17 May 2021 14:29:17 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Rhys Woolley! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-150299-J7X6R for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Fri, 18 Jun 2021 11:55:51 GMT von Salvino Scherillo Senior ECM consultant
Have you found a solution?
