Veröffentlicht Mon, 07 May 2018 15:48:27 GMT von Callum McGlynn Technical Solutions Manager
I am running an upgrade install for a customer.
Whenever I try and run the regular docuware installation to upgrade their database I am getting an error stating that "Exception has been thrown by the target of the invocation"
If I try and run the SystemUpgraderTool I get the same error but with the expanded message of -
"This implementation is not part of the Windows Platform FIPS validated crptographic algorithims"
Any ideas how to get around/resolve this error would be greatly appreciated.
Veröffentlicht Mon, 07 May 2018 16:05:46 GMT von Christopher Ure Software Support Analyst
Callum,
You need to disable FIPS compliance in the Local Policies. Please see http://docs.trendmicro.com/all/ent/sc/v3.0/en-US/cmcolh/t_fips.html for more details on how to do so.
Christopher Ure
Software Support Specialist
Support Team GREEN - Americas
Veröffentlicht Mon, 07 May 2018 16:26:24 GMT von Callum McGlynn Technical Solutions Manager
Hi Christopher,
Many thanks for your response. Can I just clarify... The customer is looking at running a split install (1 x DMZ, 2 x App, 1 x DB)
Do all of them need to have FIPS disabled?
Regards,
Veröffentlicht Mon, 07 May 2018 17:16:43 GMT von Christopher Ure Software Support Analyst
You should remove it from any server that hosts a DocuWare component.
Christopher Ure
