After building a numeric field I realized it should be a text for a mask to work.  I tried to delete the field in configuration and I get the following error.
ALTER TABLE DROP COLUMN failed because column 'TAX ID" does nto exist in the table 'CORP_ACCOUNTING"
I tried to rename it then delete it buw again I get the same error.  I rebooted the server to see if the MSSQL server would re-sync but the field is still in the cabinet and can not be deleted.
