Veröffentlicht Mon, 22 Nov 2021 22:39:28 GMT von Anthony Harbonville
Would you be able to get me an example of code (C# API .NET) that creates a indexation select list (Fixed and external)? There are fonctions, elements in the support .NET API that seems to exist in order to do that (SelectListExpression, SelectListFilter, SelectListInfo, SelectListInfos, SelectListKind, SelectListResult, SelectListType, SelectListValuesQuery, SelectListValuesResult) but i can't find an example of how to mix those to create a select list.
Veröffentlicht Mon, 29 Nov 2021 22:39:28 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Anthony Harbonville! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-165403-K1H8J for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Mon, 05 Jun 2023 14:43:16 GMT von Alexandre Prieur Consultant R&D
<p>Hi Anthony and Matthias,</p> <p>did you find an answer to this question ?</p> <p>I need to execute a query, I've set up a SelectListExpression, but I don't find wich class can execute it.</p> <p>If you have any idea, please let me know.</p> <p>Thank you</p>
Veröffentlicht Fri, 23 Jun 2023 10:11:21 GMT von Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Alexandre Prieur,<br> <br> there is no possibility to create a select list with the API currently.&#160;<br> <br> A workaround would be to use a separate file cabinet as a source for select lists and then add/update/delete entries in this file cabinet.<br> <br> Regards<br> Tobias Getz<br> Team Leader Product Management<br> DocuWare GmbH
