Veröffentlicht Wed, 01 Dec 2021 20:56:23 GMT von Grzegorz Laszczkowski
Is it possible to create index value profile and to define a query with 'Is (where clause) rule' referencing to another file cabinet?
Veröffentlicht Wed, 08 Dec 2021 20:56:23 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Grzegorz Laszczkowski! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-166127-Z0W7W for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Wed, 08 Dec 2021 21:09:28 GMT von Jon Weston File IT Solutions Sr Application Developer and RIM specialist
I've found that the 'Is (where clause)' is fairly restricted and not very well documented - sometimes you can use it like a regular SQL statement and sometimes you can't.  I know that you can do what you want if you switch it to use a SQL statement instead of the rules editor and the only helpful note I have is that you need to use the fully-resolved server name, like this:
<server name>.dwdata.dbo.<database table name>
Here's an example from one of my development VMs that references a DocuWare file cabinet called Employee Files.  This is filtering the available documents to those that have the same Facility as what's listed for the currently logged-in user (the Employee Files cabinet has fields called First Name and Last Name):
[FACILITY] = (SELECT Facility FROM [desktop-d89t57g].dwdata.dbo.EMPLOYEE_FILES as EMPF WHERE EMPF.[FIRST_NAME] + ' ' + EMPF.[LAST_NAME] = CURRENTUSERLONGNAME())
Of course, this will only work in an on-premise system because you can't use SQL statements in a cloud system.
