Veröffentlicht Mon, 12 Mar 2018 17:47:28 GMT von David Miguel Trujillo
Hello!,
I'm trying to update from DW 5.1c SP2 to 6.12,
The first step is to install DW 6.7, when i execute the installer, i get the next message:
"A newer version of DocuWare was found to be already installed"
I'm almost sure that I have version 5.1c Installed,
Could you give me some idea about this?
Thanks, David.
Veröffentlicht Mon, 12 Mar 2018 18:41:42 GMT von Christopher Ure Software Support Analyst
David,
This error occurs if you've already started running DocuWare Setup for a newer version than you are currently trying to install: for example, you ran 6.12, realized you ran the incorrect setup, and then proceeded to try to install 6.7.
I suggest you open a support request at http://support.docuware.com so that we can get a technician to assist you with rolling back just the setup package.
Christopher Ure
Software Support Specialist
Support Team GREEN - Americas
