Veröffentlicht Mon, 20 Nov 2023 22:37:09 GMT von James Eubanks ATS 2
I am building a system where I fill a PO table based on a Req table where the end user indicates which rows of the Req table they would like to have on the PO.
I cannot get the advanced matchcode system to pull only the row indicated by my GV. I have tried using the system row number and another column I created just for line numbers but the expression is similar: DW_REQ_TABLE[SYS_ROW_NUMBER]_S = GV_Current_Line_ . Both fields are numeric.
The system will pull the whole table just fine without the matchcode but will not pull just the one row on each loop.
Anyone have any ideas?
Veröffentlicht Tue, 28 Nov 2023 00:00:10 GMT von Matthias Wieland Senior Director Support EMEA
Dear James Eubanks! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-217345-H7J0D for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
