Veröffentlicht Tue, 12 Jan 2021 18:47:30 GMT von Coleman Groves Systems Consultant
Email PDFs can be imported to the trays, but below is the message I get when attempting to run the indexing feature.
What is the port required for Intelligent Indexing?   If I can get this information I can verify it is accessible prior to opening a ticket with DocuWare.
DW returning: The last attempt with intelligent indexing service failed, a connection to the service could not be established
Veröffentlicht Thu, 14 Jan 2021 05:52:45 GMT von Fabian Kall - left 01.22
There is a nice list of the used ports listed in this Knowledge Base article:
https://support.docuware.com/en-us/knowledgebase/article/KBA-34951
However, Intelligent Indexing works over http/https, so use Your preferred tools to check layers 2/3 for connections to the url of the Intelligent Indexing Service, which you can find in the intelligent indexing module of the web configuration.
It might well be a DNS issue, so You may want to verify the the URL can be properly resolved.
