Veröffentlicht Wed, 27 Feb 2019 18:45:55 GMT von John DeLaat
Running version 7 cloud - I am trying to find a "value" in a string with fulltext and cannot get any results returned.  I tried "*xxxxx*" and no results.  I am searching for the 23032 in the string below, what would be the syntax in fulltext to find that?
1342303250
Veröffentlicht Thu, 28 Feb 2019 05:42:45 GMT von Gilles Sauvagnat Altexence
Hi
Do you search with only the full text index, or do you also search with an other index ?
If yes, is wildcard actived for the other index. ?
If yes, does the value searched  in the index contain a space ?
If yes to all the questions above, too bad for you (and other users) you found a bug (under investigation)
Best regards
Gilles
Veröffentlicht Thu, 28 Feb 2019 11:07:34 GMT von John DeLaat
Only searching using full text, no other filelds.
Veröffentlicht Thu, 28 Feb 2019 11:45:00 GMT von Gilles Sauvagnat Altexence
*23032* should work
Except if 0 (number) is misinterpreted and OCRed as O (letter O) 0, 8, B, i, l for instance are good candisates for misinterpretation with OCR engine
Try different value without 0
If nothing is found,  sounds like a problem with fulltext on your DW organization, you should open a SR, fulltext might be broken on your organization.
Gilles
