Veröffentlicht Wed, 06 Jun 2018 13:11:41 GMT von John DeLaat
Setting up a form that is going to use Automatic Number, when I add it to the form, the drop down for Number Group shows "No Number Groups Defined" and will not let me continue on.  Where do you setup the number groups?
Veröffentlicht Wed, 06 Jun 2018 13:17:43 GMT von
Hi john,
you can setup them in the storedialog.
BG
Martin
Veröffentlicht Wed, 06 Jun 2018 13:31:39 GMT von John DeLaat
I do not see how.  Can you point me to the documentation on how to do it?
Veröffentlicht Thu, 07 Jun 2018 13:15:19 GMT von
Hi John,
open docuware web configuration --> open the archive --> open dialoges --> open a store dialoge -->
click on a various field --> set it to automatic numbering --> here you can create one or more automatic numbering configurations.
After you have done this you can set the field back to standard an save your actions.
now you should have the configured automatic numbering in the form configuration to chose.
Yes, it is unbelievable complicated, maybe someone else have an easier way to do this?!
Veröffentlicht Wed, 13 Jun 2018 06:22:48 GMT von Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Martin,
currently as of 7.0 Beta there is no easier way of creating automatic numbering.
