Veröffentlicht Fri, 04 May 2018 18:51:47 GMT von Jason .
If I want to connect to a table in Microsoft NAV to fetch values for a Select List in DocuWare, I first need to create a web service on the NAV side and connect teh Select List to the web service using some type of a call out, correct?  Where can I get more details on this?
Veröffentlicht Wed, 16 May 2018 08:04:49 GMT von Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Jason,
unfortunatly a select list cannot access a web service. You need to have some workaround to use the values from Dynamics NAV.
A select list can either access a text file or a database table to show the entries, so somehow you need to access the NAV database directly or copy the data from NAV to another database which can be accessed from the DocuWare system.
I hope this helps a little bit.
Tobias
