Veröffentlicht Tue, 09 Mar 2021 23:24:27 GMT von Edwin Fabian Donato TI
Recently a possible integration with a service that receives SOAP webservice has come out. The question is aimed at whether DocuWare can connect to this type of webservices from its native workflow module and if there are any conditions for this type of connection.
Veröffentlicht Wed, 10 Mar 2021 10:23:47 GMT von Léo BIANCO
If you want to be able to connect to your webservices from the Workflow Designer you must have a SOAP webservice.
First add the webservice in the "Webservices" page, in your configurations, and test the connection to your webservice.
Personnally I usually do webservices in .asmx (ASMX) or .svc (WCF) using SOAP. The methods are automatically found by DocuWare in your workflows.
Hope it helps
