Veröffentlicht Mon, 30 Aug 2021 10:01:14 GMT von Peter Ettinger
While executing multiple checks in an workflow i would like to add some values (i.e. different Errors/Warning Text) to a keyword variable. is that possible and how?
Veröffentlicht Tue, 31 Aug 2021 06:01:29 GMT von Fabian Kall - left 01.22
When You edit a keyword variable in a data assignment activity, there is a checkbox which in German says 'Ersetzen' (I guess it says 'Replace in an English system?) which is checked by default.
With this, You tell the Workflow manager not to replace the complete content of the keword field with the right side of of Your assignment, but to append to it.
Be wary of separation characters in whatever Your new value is, see here:
https://support.docuware.com/de-de/knowledgebase/article/KBA-36107
Veröffentlicht Tue, 31 Aug 2021 06:29:43 GMT von Peter Ettinger
Just to be completely sure. So in my case i have to deselect the option "replace". After doing so, the new string will be concatenated to the existing entrys in the keyword field?
Veröffentlicht Wed, 01 Sep 2021 17:22:34 GMT von Fabian Kall - left 01.22
Yup!
