Veröffentlicht Mon, 31 Mar 2025 16:08:09 GMT von Joann Pendleton Data Analyst
Support had sent me a method to enter a task with multiple decisions so that each task would need to be validated until the end.  Unfortunately it does not work the way I'd like in that the list of tasks all show up and you can confirm them all at once (by appearances) but that does not work.
I thought, parallel tasks would do it, but the same thing happens, the system only confirms one task at a time and yoiu really can't tell which task has been confirmed.  It works exactly the same as a single task with multiple decisions.
I will have ten decisions and each one will use a Select list to indicate Completed or Not Applicable.  Not sure if that is throwing things off.
Is there a way to complete all tasks in a set of decisions.  It seems that Assigning data only works for one task at a time.
Trying to avoid ten separate emails with ten separate tasks!
Veröffentlicht Tue, 08 Apr 2025 00:01:24 GMT von Matthias Wieland Senior Director Support EMEA
Dear Joann Pendleton! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-259379-W0L9J for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
