Veröffentlicht Fri, 12 Jul 2019 23:50:54 GMT von David Blake Ricoh USA Sr. Solution Integrator
Is Intelligent Indexing supported for AutoCAD drawings?  We have NOT yet tested this.  Running version 7.0.
Update:  My own testing has proved IIX does indeed function, to the limits of the dpi or compression of the DWG file itself.  Text is quite compressed.  The smallest text does not successfully OCR.
Veröffentlicht Fri, 12 Jul 2019 23:51:54 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear David Blake! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-71673-G3Q8Q for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
