Hi Pierre,
Check-Out to document tray should be:
PUT {{ServerUrl}}/{{Platform}}
/FileCabinets/
{{FileCabinetId}}
/Operations/ProcessDocumentAction?docId=
{{DocumentId}}
"DocumentAction": "CheckOut",
"DocumentActionParameters": {
"$type": "CheckOutActionParameters",
"FileCabinetId": "b_99f4b29d-a2b0-4196-a4a6-67cb74fd865c"
Check-In from document tray should be:
/FileCabinets/
{{DocumentTrayId}}
{{DocumentId}}
"DocumentAction": "CheckIn",
"$type": "CheckInActionParameters",
"Comments": "",
"DocumentVersion": {
"Major": 2,
"Minor": 0
Note that the DocIDs are different for Check-Out and Check-In.
Merging of sections is called "staple" (1 section) and should be:
POST {{ServerUrl}}/{{Platform}}
/FileCabinets/
{{DocumentTrayId}}
/Operations/ContentMerge
"Documents": [
221,
220
"Operation": "Staple",
"Force": true
Note that stapling is only supported in document trays. This ensures that documents are not lost in the filing cabinet under any circumstances.
Also, if the documents are already "clipped" (2 sections), you must first unclip and then staple.
/FileCabinets
/{{DocumentTrayId}}
/Operations/ContentDivide?docId=
{{DocumentId}}
"Operation": "Unclip"
So the procedure would probably be:
- copy the document to a document tray (Transfer)
- unclip
- staple
- store
- delete the old document in file cabinet
Product Manager | DocuWare GmbH
