Posted Sat, 28 May 2022 19:10:29 GMT by Steve Shriver Application Specialist
Does the DocumentTool.exe Restore Program update the LAST_ID field in the dwdata.file cabinet name_idt table when restoring from document folders where the DocID of the documents is newer/higher than the last DocID that was created by storing a document in a previous version of the DB?
Example, the database was restored to a new server and the system upgraded to a newer version of DocuWare. Due to some issues the older version was used and documents added after the DB was restored and upgraded. We have recovered all of the newer documents to the newer server by using the DocumentTool.exe program. However, the last DocID in a given file cabinet will now be higher than it was when the DB was restored.
Will we have to update any fields in the DB, or can we assume that DocumentToll.exe did this for us?
Many thanks,
Posted Sun, 05 Jun 2022 00:00:33 GMT by Matthias Wieland Senior Director Support EMEA
Dear Steve Shriver! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-178065-G9D0R for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
