Posted Thu, 15 Mar 2018 13:29:43 GMT by Crossroads Admin
How do I make a custom field show up as one of the columns in the Task List?
Thank you
Posted Thu, 15 Mar 2018 15:45:30 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Assuming you are referring to a Workflow Task, open the Workflow Designer, double click on the workflow to open the graphical editor.
In the button bar at the top, look for the icon labelled Task List. In there you can add and remove fields from the Task List. Note that you must re-publish the workfow for the setting to take affect, no active instances will reflect the change, only new ones started with the new version.
Posted Thu, 15 Mar 2018 16:19:40 GMT by Crossroads Admin
Thank you Phil!
Posted Fri, 16 Mar 2018 11:26:44 GMT by Gilles Sauvagnat Altexence
Dear Phil,
As far as I know the workflow task list does not require to re publish the WF hence no need to wait for a new instance (at least this is the case in 6.11-6.12)
You just need to refresh the web browser.
Best regards
Gilles
