Posted Thu, 03 Nov 2022 04:25:26 GMT by Jason Scott
I need a list of documents from the current month. I've tried this https://support.docuware.com/en-us/knowledgebase/article/KBA-36650 I keep on getting a Wrong Condition error. What is the correct format meant to be, or is there another way to do this?
Posted Mon, 07 Nov 2022 10:40:52 GMT by Simon H. Hellmann Toshiba TGIS GmbH |
Hi Jason,
the KB article does not really mention it, but it is only necessary for text fields.
If you have a date field, you can just use the filter option "within the last" and select 1 month, see Screenshot.
Posted Mon, 07 Nov 2022 22:51:56 GMT by Jason Scott
Hi Simon,
The KBA seems very specifically about DATE fields, so I'm confused by your response regarding the TEXT fields.
Also, filtering by "within the last 1 month" returns documents from the past 30 days, and not the CURRENT MONTH as per my quesition.
Posted Thu, 01 Dec 2022 15:43:54 GMT by Gerardo Lisanti Product Manager
Hi Jason,
try to use the "is (where clause)" condition with "THISMONTH".
Posted Thu, 01 Dec 2022 22:50:32 GMT by Jason Scott
Hi Gerardo,
UPDATE: This actually does work on 7.7. Thanks for this
Below is what I get on 7.6 which is where i was testing this.
Wrong condition! Field : DWSTOREDATETIME Value : THISMONTH
