Posted Mon, 15 Oct 2018 11:43:47 GMT by Casey Miller Director of Technical Services
Where can you remove the option for the user to see the "Edit Select List" when using a select list in the web client. They are on the cloud and the users only have the Read and Edit Profiles assigned to them. What option gives them this right?
UPDATE: Looks as though this may not be possible on the cloud. Very dissapointing. What is the point of forcing a select list when the user can just add to it?? Support is looking into it with the cloud team.
Posted Wed, 17 Oct 2018 10:43:39 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Casey,
That option can be set in DocuWare Administration under General > User Administration > Functional Profiles.
Select the profile and expand DocuWare Configuration. All of the options you need are found there. Eventually, Profiles etc will be in Configurations but for the moment they are still in Administration.
https://www.docuware.com/sites/default/files/forums-images/FuncProfile.png
Posted Wed, 17 Oct 2018 10:59:09 GMT by Casey Miller Director of Technical Services
Thanks, Phil! That worked. I will update the support case as they were looking into it and we got stuck yesterday.
