Posted Fri, 12 Oct 2018 01:54:58 GMT by Kim Anthony Luna
We are trying to configure an Autoindex process for documents that will have to retrieve data from multiple tables from an external database.
I have noticed, however, that an Autoindex instance can only be configured with 1 database connection that points to a single database table.
What is the best practice if you need to retrieve data from multiple tables? Should we assign multiple Autoindex processes to a document?
Thanks!
Posted Fri, 12 Oct 2018 10:03:12 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Usually, if you need data from multiple tables and the query is complex, you create a View in the database, and point AIX at the view.
Posted Sun, 14 Oct 2018 15:18:00 GMT by Kim Anthony Luna
I get it. Okay we'll try that approach. Thank you Phil!
