Posted Tue, 08 Jan 2019 14:21:05 GMT by Craig Heintz SE
I have set up a transfer from On-Prem to the cloud and tested it and it works.
I tried to set up a Cloud to On-Prem transfer and I do not get the same choices.  Mainly the Other System selection for destination is not available.  (picture attached)
Am I missing something?
https://www.docuware.com/sites/default/files/forums-images/transfer_screen_shot_from_cloud.png
Posted Tue, 08 Jan 2019 14:28:52 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Craig,
Transfer from Cloud is not available. You can only use Synchronization. This is problematic if version control is enabled since you can only use Transfer for version controlled cabinets. The only method then is to create a duplicate Cloud cabinet without version control and perform a Transfer from the source cloud cabinet to the target cloud cabinet. Then use Synchronization to bring the documents to on-premise.
Posted Tue, 08 Jan 2019 17:18:19 GMT by Craig Heintz SE
Yes, i get it.  I actually had a different need but did basically the same thing.  I have two On-Prem Cabinets and One in the cloud.  I Sync to one of the on Prem Cabs, then transfer out what I need to the 3rd cabinet.
