Posted Fri, 14 Aug 2020 15:21:39 GMT by Steve Shriver Application Specialist
What is the proper syntax to test for an empty result when using VB Script in a workflow after looking up a value in a File Cabinet or external data source?
For example, Using a file cabinet lookup that should return VendorName, then updating an index value of the document with Iif().
So should I use
Iif(GV_VendorName = Nothing, "No Match Found", GV_VendorName)
or
Iif(GV_VendorName = "", "No Match Found", GV_VendorName)
or are these statements equivalent?
Any and all clues appreciated,
Posted Fri, 14 Aug 2020 19:13:57 GMT by Jon Weston File IT Solutions Sr Application Developer and RIM specialist
Based on advice from DocuWare techs a couple of years ago I use both of those, GV_VendorName = Nothing OR GV_VendorName = "", that way my bases are covered
