Publicado Wed, 11 Aug 2021 13:19:08 GMT por Morten Ravn
In 7.4 online if I create an index value profile with edit documents rights.. to a role
But this role has not read rights assigned also..
If i then go into user management and select the role.. when i then click on File Cabinets.. then suddenly the read rights gets assigned via the "Standard profile" read.. even if the role is not assigned to this role in the stanard profile..
Is this something new in 7.4..
and if so then the rights are not a sum of rigts.. because you then can have read as stanard.. but the limit access to documents if they are meet by the index value profile ?
Publicado Wed, 18 Aug 2021 13:19:08 GMT por Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Morten Ravn! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-157673-B2J2J for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
