Publié Thu, 02 Jun 2022 14:27:58 GMT par Steve Shriver Application Specialist
Is it necessary to upgrade the DocuWare DB to V3 before upgrading from version 7.x to version 7.6 for on premises systems currently using the V2 database?
If so how is this done or is there a document outlining the steps required?
Publié Thu, 02 Jun 2022 15:43:41 GMT par Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Steve,&nbsp;<br> <br> you can continue to use the V2 database.&nbsp;<br> A database upgrade is only required if you are using the internal database V1.<br> You can find more detailed information about this in the "What is new in DocuWare Version 7.6" document.<br> <br> <br> Greetings from Germany,&nbsp;<br> Simon H. Hellmann<br> DocuWare System Consultant
Publié Thu, 02 Jun 2022 16:07:37 GMT par Steve Shriver Application Specialist
Thank you for that info Simon. I do have one customer that want's to upgrade his DocuWare DB due to some security concerns. In a case like this is it necessary to engage DocuWare Professional Services, or can the MySQL DB be upgraded to the latest version without problems?
Thanks again,
