Publié Mon, 07 Oct 2019 07:47:07 GMT par Martin Kreft
Hello.
How can i upload a Document with some index data via java script?
I used a .net application to upload documents via drag and drop.
Now i have to find a solution to do this with java script.
Are there any programming examples for this issue?
Publié Mon, 07 Oct 2019 14:40:49 GMT par Joe Kaufman Manager
Martin,
The .NET code is just a wrapper around the Platform SDK resources which can be called from any language. If you do a Google search on the following:
docuware platform "non-.net"
you will find several posts about that. More recently, DocuWare has even released a Postman collection of examples that illustrate how to perform calls to the Platform SDK from any web-capable language or scripting tool (e.g. curl):
https://developer.docuware.com/rest/examples/postman-collection-download.html
There is also a link to some node.js examples there which may translate more easily into JavaScript...
Good luck!
Publié Mon, 07 Oct 2019 14:44:52 GMT par Martin Kreft
Thank you very much.
This is exacly what i was looking for.
