Publié Tue, 10 Mar 2020 07:25:13 GMT par Mayra Rossi
How can I retrive count of row in table field?
Publié Tue, 10 Mar 2020 09:01:58 GMT par Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Mayra,
if you are using the .NET API, you can retrieve this info via DocumentIndexFieldTable.Row.Count() ( see Documentation )
Doing so in the Workflow Designer is probably not possible without getting all the values and counting them with a loop.
Publié Tue, 10 Mar 2020 09:15:47 GMT par Mayra Rossi
I found this solution to avoid loop
UBound(DW_TABLE_FIELD[XXX], 1) - LBound(DW_TABLE_FIELD[XXX], 1) + 1
Publié Wed, 14 Oct 2020 19:29:23 GMT par Jon Weston File IT Solutions Sr Application Developer and RIM specialist
This will work in Workflow Designer: DW_TABLE_FIELD[XXX].Count()
