Publié Tue, 17 Sep 2019 18:19:18 GMT par Steve Shriver Application Specialist
Are the instructions for using a modifies Text Recognition template still valid in v7.1 (they are listed for version 6)? I have documents where DocuWare mistakes I for 1 and S for 5 and wondering how I might tweak that.
Any clues appreciated,
Publié Tue, 17 Sep 2019 18:29:37 GMT par Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Steve,
No change - follow the same directions. I doubt you will find a tweak to fix that problem. Depends a lot on the font. OCR does a great job but if you encounter such an issue rarely can the template be tweaked to resolve it. It is simply life with OCR. You would be better off testing various fonts.
I assume that you are dealing with scanned documents?
If so you are dealing with nothing more than a picture consisting of black and white dots. Consider resolution.
