Publié Mon, 03 Jan 2022 17:04:24 GMT par Jalila Manal
I would like to lock the change of index entries after the validation of a document.
Do you have an idea how we can do that?
Regards,
jalila
Publié Tue, 11 Jan 2022 00:00:15 GMT par Matthias Wieland Senior Director Support EMEA
Dear Jalila Manal! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-168011-S2N4C for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Publié Fri, 04 Feb 2022 09:02:55 GMT par Morten Ravn
Perhaps you can solve this by adding a value to a field and then uses index value profiles to enable /disable index changes if this value is present /not present...
Publié Fri, 04 Feb 2022 09:03:56 GMT par Morten Ravn
but this does require that the same users dosen't have read/edit standard profiles rights
