I want to set up an excel list that has wrong supplier names in column A and correct supplier names in column B. Whenever a scan has been succesfully indexed, a workflow process shall automatically compare the indexed supplier name with the excel list and in case the indexed supplier name can be found in list A (thus a wrong supplier name), the system shall take the correct supplier name in column B instead and overwrite the index value.
Is there any possibility how to set up this process?
I'm looking forward to hearing from you,
Andreas
