Publicado Tue, 16 Jan 2018 06:25:08 GMT por Erich Heinz
I want to set up an excel list that has wrong supplier names in column A and correct supplier names in column B. Whenever a scan has been succesfully indexed, a workflow process shall automatically compare the indexed supplier name with the excel list and in case the indexed supplier name can be found in list A (thus a wrong supplier name), the system shall take the correct supplier name in column B instead and overwrite the index value.
Is there any possibility how to set up this process?
I'm looking forward to hearing from you,
Andreas
Publicado Tue, 16 Jan 2018 11:41:39 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
I would suggest that an Autoindex workflow can do this for you. You would need to use either a database or a flat text file rather than an Excel file.
Publicado Thu, 18 Jan 2018 09:11:51 GMT por Erich Heinz
Could you explain this more in detail
Best Regards,
Andreas
