Publié Thu, 23 Apr 2020 14:38:21 GMT par Alain Steiner SAE
I would like to use DocuWare import jobs folder to manage .xml metadata. (Created via Kofax AutoStore)
I am not able to find the right settings to do it working.
In attachement, what I did until now but without success.
Thanks a lot for your inputs
Alain
Publié Thu, 23 Apr 2020 14:40:03 GMT par Christopher Nicoli Project Manager-Sr Systems Engineer
if you are using Kofax Autostore you do not need to use the xml meta data with an import job. AutoStore has a DocuWare connector that can be utilized to index directly on the screen and then store directly to file cabinet.
Publié Thu, 23 Apr 2020 14:53:48 GMT par Alain Steiner SAE
Hello Christopher,
I forgot to specify that I use DocuWare Cloud.
Is the DocuWare connector compatible with the Cloud version?
Alain
Publié Thu, 23 Apr 2020 15:07:17 GMT par Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Alain,
the metadata file may not end with .xml - instead, the file ending needs to be .dwcontrol
So your test file would be named
style-guide-fr.dwcontrol
DocuWare import ignores other file endings, including .xml, when looking for metadata files.
Publié Thu, 23 Apr 2020 20:18:37 GMT par Christopher Nicoli Project Manager-Sr Systems Engineer
i believe it is compatible with cloud
Publié Fri, 24 Apr 2020 06:09:16 GMT par Alain Steiner SAE
Hello Simon,
It is processing now!
I did the change you suggest => .xml to .dwcontrol
And I also change the settings in the Document processing :
Identify document corresponding to dwcontrol file:
  • by their file names  (selected)
In AutoStore, the “XML Generator” is not compatible. This component seems only able to send .xml as metadata =>
I use the “Document Writer “ component to create the “.xml” with the relevant RRT and change the extension to .dwcontrol.
@ Christopher
I try to use the “Docuware connector” but without success. I am not able to connect...
In the AutoStore help, I found:
Restrictions and limitations
This component works with the DocuWare server version 5.1b, 5.1c, 6, and 6.1 – 6.9.
and no mention of the Docuware Could version.
If anybody have exprience with that I will appreciate
Alain
Publié Fri, 24 Apr 2020 16:13:06 GMT par Christopher Nicoli Project Manager-Sr Systems Engineer
their help is poorly updated..i'll test it on my end to see if i can get it to work.
