Registrato Thu, 30 Jun 2016 19:40:24 GMT di David Blake Ricoh USA Sr. Solution Integrator
A customer wrote the following experience:
"We noticed some slowness in the webflow processes (during testing). At the time we wrote it off to people accessing it (Webflow) remotely.
It is still continuing to be slow. It’s more noticeable at the approval point – where the user clicks "Approved" to advance the invoice. It took one user almost 20 minutes to get through 4 invoices."
Five months ago we've upgraded to Fortis 2.8. Webflow was newly installed and has only gone to production for the first time last month. Fortis sits on a Windows 2012 R2 box with 4GB RAM. There are additional separate servers for IIS and Inflo with the same Windows configuration.
Any recommendations to hasten the actions of Webflow?
Registrato Thu, 30 Jun 2016 20:44:28 GMT di Tyler Behuniak Professional Services Assistant
David,
We have recieved the ticket from John Lawrence under the Support Request # 248077 and are currenlty working with him on the ticket.
Registrato Mon, 11 Jul 2016 21:12:48 GMT di David Blake Ricoh USA Sr. Solution Integrator
Following up if there was any movement or progress regarding this issue or the ticket.
Registrato Mon, 11 Jul 2016 21:18:00 GMT di David Blake Ricoh USA Sr. Solution Integrator
Customer reported having an issue printing a single page from a document in Fortis using MS IE. Can print through FireFox. Is there a known issue with MS IE regarding printing?
https://www.docuware.com/sites/default/files/forums-images/Print%20Single%20Page%20Error_0.jpg
Registrato Mon, 11 Jul 2016 21:18:49 GMT di David Blake Ricoh USA Sr. Solution Integrator
https://www.docuware.com/sites/default/files/forums-images/Print%20Single%20Page%20Error_1.jpg
Registrato Mon, 11 Jul 2016 21:18:56 GMT di David Blake Ricoh USA Sr. Solution Integrator
https://www.docuware.com/sites/default/files/forums-images/Print%20Single%20Page%20Error_2.jpg
Registrato Tue, 12 Jul 2016 13:54:06 GMT di Chad Folts Professional Services Engineer
David - Can you have the user "Disable Silverlight printing" and try to print the page again?  If that does not resolve the issue, please open a new Support Request through the Portal
https://www.docuware.com/sites/default/files/forums-images/fblue.png
