Registrato Mon, 11 Jun 2018 16:22:34 GMT di Michael Weingand Professional Services Manager
New install.  On-Prem.  6.12 with hotfix.
LDAP with Active Directory setup.
Select list draws from AD to select Group root node distingushed name and User root node distiguashed name.
IN Sync Setup the DocuWare Groups to LDAP groups, the drop down shows (none).
Any advise???? PLEASE!!!!!!
Registrato Mon, 11 Jun 2018 16:31:26 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Michael,
It's a bit difficult to give advice here. Sometimes the problem is in the AD setup. Given that the groups are not showing I suspect something amiss with AD since DocuWare issues a basic LDAP query to list groups etc.
Can you open a support request so that we can look at it with you?
Registrato Mon, 11 Jun 2018 17:36:53 GMT di Michael Weingand Professional Services Manager
Thank Phil, Will do.
