Registrato Wed, 25 Jun 2025 11:49:41 GMT di Maingwe Mbao Technical services Manager
I am trying to Docuware cloud in a tria version for certification purposes, instead of creating an empty cloud trial, i imported the preconfigurations.
How can I revert to an empty cloud trial.
Thank you in advance.
Registrato Wed, 25 Jun 2025 13:50:02 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Maingwe Mbao,
you just create a new cloud trial without preconfiguration.
Removing the preconfigured solution is a lot more time consuming.
Registrato Thu, 26 Jun 2025 09:20:46 GMT di Maingwe Mbao Technical services Manager
Thank you Simon,
A quick question; Since i have already used my email address with the first trial request, how can I cancel the existing cloud trial so that I can start afresh.
I will appreciate your guidance on this.
Registrato Mon, 30 Jun 2025 14:22:58 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Maingwe Mbao,
you can just create a new trial with the same email address.
There is also another way with a little bit more effort: Just head over to the DocuWare Configurations and delete all file cabinets, document trays and everything else. As there are some dependencies, you might have to delete items in a special order. e.g. you need to delete workflows before you can delete the assigned file cabinet.
DocuWare GmbH
