Registrato Wed, 02 May 2018 10:44:00 GMT di Daryl Foxhoven Sr. Systems Engineer
We have a user  referencing a list that they use called MY OVERVIEW DOCUMENTS and there is the number that is displayed that  reflects the number of items that need the user's attention. Inexplicably, and with no warning, the interface appears to decide to update itself with a MY OVERVIEW DOCUMENTS list that has some large number and content that is not relegated to the user Then, again with no warning and on its own the interface changes again.  Anyone know why this is happening and it is random.
https://www.docuware.com/sites/default/files/forums-images/Leslie%201.png
https://www.docuware.com/sites/default/files/forums-images/Leslie%202.png
Registrato Wed, 02 May 2018 13:12:15 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Very odd. The bigger list contains more data than the other. You could almost believe that there are 2 lists with the same name.
I would delete the list and recreate it with a slightly different name and see if the behavior persists. If it does, then something is changing the data in the background I think.
