Registrato Thu, 31 Oct 2019 22:31:13 GMT di Phillip Enns Systems Admin
Appears a bug with duplicating autoindex jobs.  Attempting to create a autoindex job and then duplicate to make some minor changes, changing file cabinet event triggers, and appears to be populating to all duplicated events?  Unable to edit these triggers independently of each other after duplication.  Anyone else having this issue on version 7 (Build: 7.2.0.11082) ??
Registrato Mon, 04 Nov 2019 17:06:31 GMT di Gerardo Lisanti Team Leader Product Management
Hi Philip,
thank you for your feedback!
That's a known issue which was already fixed. It will be part of the next Minor Update which will be released soon. Latest on Patchday November (last Friday of the month). I suggest you subscribe to the Support Announcements, in case you didn't already, so you will be notified when it is available.
DocuWare Cloud is updated more frequently. The issue should be fixed within the next business days
Manager Product
