Hi, i wanted to insert data in an external DB from docuware , is it that possible ?. If it is possible how will be the way to do it ?Thanks Regards
I think "Autoindex" is what you are searching for. You can read data from an external DB to fill index fields in docuware AND you can manipulate fields in external DB ...
Ottieni aiuto
