Registrato Thu, 05 Apr 2018 15:15:54 GMT di Jon Neff Kelley Imaging Solutions Engineer
Has anyone created a utility to run through the database and verify coresponding images are in the Storage Location?
Registrato Thu, 19 Apr 2018 17:53:27 GMT di David Moore Co-Contract Administrator
If you export the file cabinet to a duplicate you have created all of the good records will MOVE to the new cabinet. The records with broken header links will remain as long as you select the delete source documents check box. If you leave the checkbox empty the good docs will COPY to the new cabinet. It will give you an Idea of the number of broken records and wont change your source cabinet. I would duplicate your related storage locations and backup the database beforehand just to be safe.
