Registrato Wed, 25 Jan 2023 08:09:32 GMT di Jamshad Mohamed Biyyathil Project In-Charge
How can restrict user from seeing folders in the same cabinet.
I have created different store and folder dialogs. and given separate permission. Still under user login under folders can see other folders too.
Is there a way to restrict thi user from seeing other folders under the same cabinet.
Registrato Thu, 02 Feb 2023 00:00:27 GMT di Matthias Wieland Senior Director Support EMEA
Dear Jamshad Mohamed Biyyathil! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-195614-C7F6C for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Registrato Thu, 09 Feb 2023 07:00:00 GMT di Martin Rothenfusser Technician Software Support
It was a local problem. This behavior only occurs on a specific laptop. Using a different browser or clearing cache and cookies solved this case.
