Registrato Mon, 24 Feb 2020 08:53:04 GMT di Chema Lopez Developer
Hi.
We have several Workflows in a DocuWare cloud instance. When we try to list those workflows by using REST API (https://CLIENT.docuware.cloud/DocuWare/Platform/Workflows) only few of them are shown.
If I access directly to one ot those hidden workflows it is shown: https://CLIENT.docuware.cloud/DocuWare/Platform/Workflows/{WORKFLOW_ID}
That workflow has three active tasks but if I list them through REST API (https://CLIENT.docuware.cloud/DocuWare/Platform/Workflows/{WORKFLOW_ID}/Tasks) only one is shown.
We have checked permissions and everything seems to be right.
The version is 7.1.
Registrato Tue, 25 Feb 2020 08:37:30 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Chema,
I realized this the hard way just some weeks ago. There are two functions to access all the workflows in the system (see here).
If you use the method
org.GetWorkflowsFromWorkflowsRelation();
you will only get workflows in which the User you used for creating the connection owns a task. All Workflows without active tasks or without tasks assigned to the logged in User will not appear with this function.
I then switched to use the second function:
org.GetWorkflowsFromControllerWorkflowsRelation();
This gets me all the workflows in which the User you used for creating the connection is a workflow controller, regardless of if there are tasks available or if he owns a task.
Registrato Tue, 25 Feb 2020 10:00:50 GMT di Chema Lopez Developer
Thank you Simon.
Since I use the REST API not the .NET library the equivalent call would be:
https://CLIENT.docuware.cloud/DocuWare/Platform/ControllerWorkflows
Still, there are several workflows that are not shown even though the logged user is controller for those.
For example, I see one workflow with one active instance in Workflow Designer but if I get workflow info through REST API it shows TaskCount=0 but there is one task.
<WorkflowTasks xmlns:s="http://dev.docuware.com/schema/public/services" Count="0" TimeStamp="2020-02-25T09:56:07.841371Z"
               xmlns="http://dev.docuware.com/schema/public/services/platform/workflow">
  <s:Links>
    <s:Link rel="first" href="/DocuWare/Platform/ControllerWorkflows/xxx/Tasks?count=50" />
    <s:Link rel="self" href="/DocuWare/Platform/ControllerWorkflows/xxx/Tasks?start=0&amp;count=50" />
  </s:Links>
  <Task Id="Id" InstanceId="InstanceId" IsRead="false" AllowDecisionStamp="true" ActivityDescription="" DocId="DocId"
        ActivityType="GeneralTask" NodeId="NodeId" WorkflowVersionId="WorkflowVersionId">
    <TaskOperations>
      <BaseTaskOperations>
        <s:Links>
        </s:Links>
      </BaseTaskOperations>
    </TaskOperations>
    <ColumnValues>
    </ColumnValues>
    <DefaultDecisionId p4:nil="true" xmlns:p4="http://www.w3.org/2001/XMLSchema-instance" />
  </Task>
</WorkflowTasks>
Registrato Fri, 06 Mar 2020 11:55:14 GMT di Chema Lopez Developer
There is also a problem I recently found.
Accessing the URL
https://CLIENT.docuware.cloud/DocuWare/Platform/ControllerWorkflows/{WF_ID}/Tasks
returns a list of tasks.
If there are several tasks each of them assigned to an user, the ColumnValue WF_Task_User_Name contains the username.
But accessing the URL of these tasks
https://CLIENT.docuware.cloud/DocuWare/Platform/ControllerWorkflows/{WF_ID}/Instances/{INSTANCE_ID}/Tasks/{TASK_ID}
returns the same WF_Task_User_Name in all tasks.
