Registrato Tue, 09 Oct 2018 12:32:46 GMT di Steve Shriver Application Specialist
I have created a file cabinet and exported the XML structure file from my v7 system. I sent this file to a customer with a new Business Server installation (v7). When I try to import this file to create a file cabinet on his system all looks well during the import process but the file cabinet creation dialog opens with only the standard defaults.
I have done this before with good results in v6.12. Is this function no longer available in version 7?
Any clues appreciated,
Registrato Tue, 09 Oct 2018 12:50:50 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Steve,
This does not sound right. Can you open an SR and provide the XML file?
Registrato Tue, 09 Oct 2018 13:03:19 GMT di Steve Shriver Application Specialist
Will do Phil.
Registrato Tue, 06 Apr 2021 17:36:36 GMT di Eric Saffle Enterprise Software Solutions
Any updates on this configuration? What was the issue keeping it from uploading properly?
