Registrato Thu, 22 Mar 2018 10:38:06 GMT di Callum McGlynn Technical Solutions Manager
Customer of ours has a request to display a list of supplier names within a field in DocuWare which is linked to a backened select list, this ordinarily wouldn't be a problem and is something we have setup many times before.
The complexity comes in that they can have upto 5 of the same supplier name in their list and only seperate which is which using the Supplier Code.
To get this to work we have come up with the idea of adding suppliername;suppliercode but this then fails the intellix match and also creates a problem with a discovery job completed further on in the workflow.
We are trying to link this to Intellix with a fixed list text file also which is an additional layer of complexity to the process.
Can anybody suggest a method to complete this which will keep Intellix working and assist the custmer in being able to choose which supplier name to use efficiently?
Registrato Thu, 22 Mar 2018 11:35:23 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Callum,
Would not a multi-column select list work here? If you index on the company name, the list will return the list of supplier codes. If you index on the supplier code, it will return the single name.
