Customer of ours has a request to display a list of supplier names within a field in DocuWare which is linked to a backened select list, this ordinarily wouldn't be a problem and is something we have setup many times before.
The complexity comes in that they can have upto 5 of the same supplier name in their list and only seperate which is which using the Supplier Code.
To get this to work we have come up with the idea of adding suppliername;suppliercode but this then fails the intellix match and also creates a problem with a discovery job completed further on in the workflow.
We are trying to link this to Intellix with a fixed list text file also which is an additional layer of complexity to the process.
Can anybody suggest a method to complete this which will keep Intellix working and assist the custmer in being able to choose which supplier name to use efficiently?
