Registrato Thu, 06 Aug 2020 18:44:04 GMT di Steve Shriver Application Specialist
When trying to use the admin tool on a 7.3 system I get a "Login token expired, contact your administrator' error using the desktop apps connect. If I change to DocuWare authentication and try to login I get a"Organization with that name not found" error.
Any one seen this before? Any clues appreciated...
Registrato Thu, 06 Aug 2020 18:45:05 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Steve Shriver! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-132229-H8L5N for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Registrato Fri, 27 Nov 2020 15:38:54 GMT di Ryan Jones - left 09.2021
Hello!
Was there a resolution to this issue? We have some users experiencing the same error message.
Thanks!
Registrato Mon, 30 Nov 2020 13:45:23 GMT di Steve Shriver Application Specialist
Ryan,
No official resolution, but I was unable to duplicate the error.
