Registrato Thu, 27 Jun 2019 15:23:29 GMT di Kim Sims Technical Solution Architect
I have several import jobs that run constantly. 2 of the jobs stop randomly.
There doesn't seem to be anything wrong with the configuration, as both function as expected when started.
How can I determine the cause of the stoppage?
Registrato Thu, 27 Jun 2019 15:24:29 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Kim Sims! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-70567-G7W7J for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
Registrato Tue, 27 Aug 2019 07:59:59 GMT di Marcus Herre Uriot GmbH & Co. KG Solution Consultant
Zwei Monate und immer noch keine Lösung? Habe dasselbe Problem. Werden dann wohl auch ein Ticket öffnen müssen.
