Registrato Tue, 10 Jul 2018 09:55:48 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Hameed,
1. I am not sure exactly what you are referring to here. Only DocuWare can login to DocuWare. Of course, a 3rd party app can leverage the DocuWare API to perform a login.
2. Yes:
http://[your server]/DocuWare/Platform/
Contains the documentation for the API. The API can be obtained from Nuget.
3. Yes
4. Yes
5. Yes
Registrato Tue, 10 Jul 2018 12:37:08 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Hameed,
The NuGet download will get you were you need to be with regard to .NET environment. For a more generic approach using HTTP request objects, I just posted several links on this forum thread:
https://www.docuware.com/forum/english-forums/docuware-help-technical-problems/rest-api-validate-user
That should get you logged in and provide examples of doing the operations you wish to do (which as Phil states, can all be done via the RESTful Platform API.
