Registrato Wed, 14 Aug 2019 22:51:47 GMT di Kim Sims Technical Solution Architect
I have begun to receive the following error when launching Workflow designer:
The requested service, 'http://irvwinvapp-134.clientname.local/DocuWare/Settings/BpwDesitnService.svc' could not be activated. See the servicer's diagnostic trace logs for more information.
I've reviewed the attached DocuWare.Bpw.Designer.log, but, can't seem to find the root cause.
Has anyone else seen this behavior?
Registrato Wed, 21 Aug 2019 15:16:02 GMT di Craig Heintz SE
Rebooting the server has resolved this issue
