Registrato Thu, 27 Jul 2023 10:14:15 GMT di Chema Lopez Developer
Hi.
I am doing some URL integration tests. I create the URL for the Basket option (p=B). As documentation shows, if I use the tw option (tw=visor) to set the target window/iframe, when storing a file the Viewer should open in that window/iframe but it always opens in a new window.
I would like to use this way:
NAVIGATOR WINDOW
[BASKET IFRAME] | [VIEWER IFRAME]
This is the HTML snippet:
<iframe src='url-integration' height='600' width='700'></iframe>
<iframe id='visor' name='visor' height='600' width='500'></iframe>
Registrato Fri, 04 Aug 2023 00:02:40 GMT di Matthias Wieland Senior Director Support EMEA
Dear Chema Lopez! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-208645-D5S6D for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
